just a couple of pictures, its still got some work, but i am getting there.
maß: (lxbxh) 200x120x80
maß ausfahren: 312x256x80
waffen: durchmesse: 256cm
gewicht: 19,5 kg
150 upm
gewicht: 19,5 kg
150 upm
Irgendwann wird es ohne Crew on board nicht mehr gehen =) . 2,56m ? Für Dich wird eine separate Arena gebaut werden müssen. :engel:
Die Gitterkonstruktion zur Verstärkung sieht gut aus.
Oh my goodness !
What a crazy design ! :jeah:
I really love this device.
Was ist das?
Ein Rasenmäher?
Hat das Teil Räder?
Bei kommt eine Frage nach der anderen.
Erzähle mal ein bischen
Dein neuer Rasenmäher oder gar ein neuer hovernder Einkaufswagentyp ? =)
Bryan, you are a very, very sick man... =)
Congrats, great design! :jeah: :jeah:
Krasses Design !
here is a small film of the finished robot:
tommarrow I have a weapon test planned. It will be
R-evolution vs. Washingmachine
I will defenaly have a video camera there. should be at least interesting.
WOW... :dafuer:
very cool design... looks great... this machine really is an eyecatcher ... =)
ZitatBryan, you are a very, very sick man...
indeed, he is... lets hope the design will work...
bryan, i love to see the video of your test.... good luck... =)
Well the test is over and the winner is
the winner by a Technical knock out:
[SIZE=3]The washing machine [/SIZE]
I guess i am the only person that is glad that the event in holland was canceled.
I had several problems with the electronics. The motor for the weapon didn´t kick on at all, and the robot only drove right, and backwards.
15 min. later(after trying to quick fix the problems --the next try:
No weapon, only right, forward and backwards both work.
another 15min. later :
Weapon works, Forward to the washing maschine. one hit and the contact to the weapon failed again.
later:
Everything working another try: 3 or 4 hits weapon stops.
later:
last try--forward hit, blade hits pavement, then my own robot.
here are some pictures (the video wasn´t worth watching)
and the robot:
needless to say i was very disappointed in the performance, but at the same time glad that it didn´t happen to me in holland.
I know where most of the problems were (electronics) and will go back to my older system with relais.
I will also go up from 12v to 24v on the weapons that will give me 400 upm instead of the 200 and alot more power.
I also have a year before the next event, so this won´t be the last test. Before i go to the next event it will run just perfect.
my goal is to cut a washing machine in 2 pieces in under 1 min.
All there is left to say is:
[SIZE=4]Washing machine, be prepared for round 2 [/SIZE]
=) =) :uzi:
