Immer wieder auf der Suche nach neuen Reglern , wieß nicht ob dieser schon mal Angesprochen wurde , aber nachfragen kann man ja immer !
The H6 (40A) Motor Controller
with Current Limiting.
A high quality 40A full H-bridge speed controller, with all the features of the H5 (servo pot and limit switch inputs, mixing etc), and also current
limiting, thermal protection and an ignition switch input.
The ignition switch controls the soft-start/ignition relay, which stops the large
in-rush current to the main smoothing capacitors, and it can also be used
as a remote kill switch.
It also comes in two versions, one runs from 12V supplies,
and the other runs from 18 to 24V.
I'm still writing the instruction sheet, it will be uploaded here shortly.
Size: 105mm x 82mm x 35mm high.
Price: £75 each.
Englisch sehr schlimm bei mir , ist ja algemein bekannt deshalb frage ich ja hier nach ! :engel:
