Ich möchte einen Bot bauen der vorne eine spitze hat die an dem Bot geschweißt ist aber weiß nicht ob das erlaubt ist .
Spitze Am Bot
There isn't any rule that doesn't allow pointy bits on your machine. You could enter with a mechanical porcupine.
The only applicable rule is the sharp edge protection. Once outside the arena, you need to cover the sharp points and edges so nobody can cut him or herself.
also darf man es ?
oder nicht ?
Look at the machines build during the years.
Ramming spikes, spring powered icepicks, pneumatic stabbers, all were tried, and dissapeared in the grey clouds of the past.
