Just to split it up from the Original Team RCC Featherweight thread.
Leo and me worked on Nebelwerfer last weekend, and it works.
Main difference with the previous versions is the size and weight of the disk. Smaller and a tad lighter.
Stats.
5Kg
Drive, Ranglebox Neptune mated to HK 2836 motors. Controllers, SimonK reflashed Afro 30A.
Weapon. TP3620 motor, 210mm diameter 1 kg hardox 500 disk. 2 stage gearing. First stage bevel gear 2.5-1, second stage timing belt with smooth pulley on the disk, 2-1 gearratio. Startup amps with tight belt, 85. Running amps 25A. Hobbyking SS190-200 ESC
Battery, Zippy Compact 3S 2700mAh
Frame, 60x10mm aluminium and 5mm HDPE
Armor, up to 30mm HDPE.
Stats.
5Kg
The post was edited 1 time, last by maddox ().
