Kleiner Tip von Team Malice...
https://www.facebook.com/groups/56319454480/user/1020600033/
Man sieht ja wie das funktioniert hat...
Alles anzeigenThe Tantrum Fight Breakdown: The one hit knockout!
Tantrum rushed across the box as we spun up and BAM one big hit then…. Nothing? But hey, our belt stayed on this time.
So, what happened?
Our motor controller burnt up because the bearing exploded and caused a massive energy spike!
During the first hit, the massive energy between Tantrum's smashing blade and our blade contacting caused our bearing to disintegrate. The excess energy had to go somewhere and caused feedback to the VEX BB speed controller blowing it up.
Malice runs an ME0909 Motor to power our Weapon, this is a massive motor that runs on 12S and 600amp+ peak. There are very limited motor controller options to get something that massive moving a weapon as heavy as ours. There’s the old reliable contactors,
the Trampa VESC and the Vex BB ESC.
Contactors and why we didn’t use them: Contactors are great for the old batteries that didn’t have the capacity to dump all their amperage all at once. Since we run lipos, if we used a contactor, we would have our batteries dump their amps and catch on fire (see Tombstones fight against Shrederator for what happens when you use Lipos with Contactors)
Trampa VESC and why we didn’t use it: The trampa vesc is a great ESC for brushless motors, but when it’s used in brushed mode (what we need for the ME0909) use a very reduced current, and the spin up time is ATROCIOUS.
Vex BB and why we used it: The Vex BB seemed like our best option because it had been shown reliable by robots like Bite Force. We thought this tantrum fight failure was caused by a faulty Vex BB as we had purchased some used ones and sometimes those can be sketchy.
The diagnosis after our tantrum fight: YAY OUR WEAPON BELT STAYED ON! Sure, our Vex BB failed, but we’ll replace it with a Brand New one and see if that does better in our next fight! The rest of the robot looks great and held up well, hopefully, we stay spinning next time!
Ich denke es würde auch ohne solch Großen Motor Funktionieren, was mich halt wundert das trotz des Riemen der Motor Blockiert haben soll, eine zusätzliche Rutschkupplung könnte aber auch schon Helfen
Mad Catter sieht auch gut aus nach dem Kampf...
Noch der entsprechende Text dazu (finde ich meistens Interessanter als die Bilder)
MADCATTER VS YETI SPOILERS!!! This year we upgraded to three big weapon motors, but before the fight we were struggling with our weapon motor gears. The gears on the motors were sliding off because the set screws weren’t holding strong enough. The misaligned gears combined with the amount of power the motors were putting out broke some gear teeth causing a chain reaction breaking all the other gears with it. To solve it for the fight coming up in the next few hours, we welded the gears onto the motor shafts. Luckily it worked great for the fight!
We got a nice gouge in our weapon tooth from hitting yeti but that was easily filled with some hard face welding. The only thing that broke on the weapon were the bearings. This would have completely seized up our weapon last year, but our new weapon motors just powered through like it was nothing!
We also tried a new drivetrain with six motors instead of last years four. It drives amazing with all that power. However, we were making use of the same motors we’ve run since battlebots 2019, so they’ve all seen 3 seasons of wear already. All our motors were very tired and it showed in this match. 5 out of 6 motors had broken shafts, bent shafts broken magnets, bad sensors, or wobbly bells, or a combination of those issues. At the end of the fight we couldn’t accelerate or turn like we could at the start. We could do victory circles really well though! (That was the only direction we could turn by the end )
For the next fight, we Frankensteined together the good parts of our remaining motors, epoxied all the magnets in place, made new motor shafts, and supported the motor shafts better in the frame.
Thanks to our sponsors @sendcutsend botkits, Monterey machine products, and Mt SAC! #battlebots #madcatter #combatrobots #robots
Mad Catter hatte eine große pit area zusammen mit Big Dill, entsprechend habe ich einige Zeit bei denen verbracht. Ich kann auf jeden Fall bestätigen, dass Calvin über die alten Motoren geflucht hat. Nach seinem Sieg bei Norwalk Havok hätte er immerhin Budget für Neue
Kaufen heißt in dem Falle mal wieder "kann man auf deren Homepage schauen". Herunterladen oder offline schauen geht leider nicht, wobei mich das ehrlichgesagt auch nicht weiter stört. Mir war da wichtiger, dass ich das unkompliziert aufm PC, Handy (Android) und Fernseher (ebenfalls Android) schauen kann.
Zitat von Mad Catterwe welded the gears onto the motor shafts.
Das hab ich mir bei meinen neuen Bots auch schon überlegt, die Großen Zahnräder bekomme ich in den Griff Sie gut zu befestigen, nur die kleinen haben mir echt Kopfzerbrechen bereitet, im Endeffekt werd ich Sie einfach mit der Welle mit WIG verschweißen, alles andere kommt einfach nicht in Frage, so eine Schweißnaht ist schnell gemacht, alles andere ist einfach zu viel Arbeit und ob es hält zeigt dann immer erst der Kampf, beim Schweißen bin ich mir wenigstens Sicher das es hält!
danke @ralf für Infos bzg "kaufen". Ist also wie ich befürchtet habe nix, was man sich dann auf seinem Rechner/Datensicherung kopieren kann. Schade. Bin anscheinend zu altmodisch...
Nicht nur Du.... Ich habe auch lieber eine Verpackung von einer Software mit einer Original-CD/DVD drin im Regal stehen, als dass ich mich dann wieder irgendwie rechtfertigen muss, warum eine bestimmte Software von einer Spionage-Software am PC gefunden wurde.
Ich werde im Freundeskreis schon dafür ausgelacht, dass ich mir ein CD-Laufwerk in meinen PC einbaue
In dem Fall kann ich die Firmen allerdings verstehen, habe ja selbst noch die Pre-Smartphone MP3 Ära erlebt. Wenn einer einer ein Lied gekauft (oder sonstwie gefunden...) hat, wurde es im gesamten Freundeskreis verteilt. Und diese haben es dann auch an ihre Freunde verteilt und so weiter... Das dürfte jedem klar sein, dass das kein wirtschaftliches Geschäftsmodell ist.
Warum Battlebots allerdings keine DVD oder Blue Ray anbietet kann ich nicht nachvollziehen.
Würd ich sofort kaufen keine Frage, aber du kommst ja schon auf normalen Weg ohne VPN Umwege aus Deutschland nicht ran!
Da hängen Sie noch immer in Staffel 2!
Das regt auch viele Builder auf. Die Unfähigkeit Battlebots ihr Produkt zu vermarkten und Geld damit zu verdienen.
Der YT-Bonusfight:
In den neueren Laptops wird das DVD-/BlueRay-Laufwerk serienmäßig eingespart. Aber wie man dann eine gekaufte BlueRay abspielen soll.... Jetzt muss halt neben jedem flachen Laptop ein separates Laufwerk stehen...
Zu den Zeiten von Commodore C64 gab es das Kopierprogramm "Kwik-Copy". Das wurde seitens des Herstellers sieben mal verkauft. Aber jeder C64-User hatte es....
Bin jetzt auch dazu gekommen die Folge zu sehen.
Spannend und interessant, auch und grade was die neueren Entwicklungen angeht.
Aber... Die Erklärung zum Flippermechanismus bei Blip war wirklich... keine Ahnung, wer das versaut hat, aber das richtige Belagerungsgerät wäre eine Balliste gewesen, kein Trebuchet.
gekaufte BlueRay
kauft keiner mehr :), dafür gibt es amazon prime, youtube, netflix,...
und wenn doch, dann kommt das Ding in die Spielekonsole
Bei mir ähnlich.
Ne kleine Korrektur zu meinem Fallsbeispiel. Das CD Laufwerk hatte ich mir mitbestellt, aber als ich den PC mit nem Kumpel aufgebaut habe, hatten wir es nicht eingebaut. Das war irgendwann September/Oktober. Bisher habe ich es noch nicht vermisst.
(Für Blue Ray und Player bin ich nach wie vor zu geizig)
Auf den Kampf Witchdoctor vs Duck freu ich mich am meisten. Hoffe der wird spannend.
Icewave vs. dragon verspricht interessant zu werden und natürlich cobalt.
Arena Spoiler zur Folge 3...
Bonus Fight zu Folge.3...
