moin
hat schonmal jemand mit den zwei gang schrauber getrieben experimentiert und ein paar erfahrungen die über die impressionen von dem schwarzen feather vom mmm2 hinausgehen?
moin
Da ich bisher noch keinen 2-Gang-Schrauber für weniger als 5 Euro in die Finger bekommen habe fehlen mir leider die Erfahrungen dazu :engel:
Dirk
Der schwarze Feather müsste ja Bonx von Tim (DRG) gewesen sein. Sorry ist bislang die einzige Konstruktion die ich kenne, die einen angesteuerten Zweigang-Akkuschrauber verwendet. Ich denke, da müsste man mal im englischem und australischem forum im featherbereich stöbern.
well it works, kinda, the 2 speed gearbox combo i used in the last version of BonX has some issues mainly because the gearboxes (dewalt) came out of second hand drills. the first version was at MMM2 and had new black and decker drills, worked perfect, only problem i had was radio interference.
if your looking at making the same system, make sure they're new. Also look for a all metal gearbox. all this make the robot drive longer.
Oh and don't change gear at full speed ![]()
yes im thinking about a use of this gears in my bot
what kind of modifis did you on the gear?
most interesting thing is how to make the switch easy enougt to use the servos.
i thougt the swich is only possible with still standing motors can i swich wile driving?
no real mode to the drills just added a way to attach the servo
switching can be done while driving, just not recommended
i just thougt the changing of gear is kind of hard for a servo becaus i need relativ much power to move the switch if its left like it was in the drill.
can u send me a close picture od the servo attach u build?
don't have any internal pictures but i know the problem, it's the outer casing of the drill, just taking out the drillmotor+gearbox should solve this
thats much more easy than i thougt ![]()
