Full Pressure Cylinder für Antweight
  • wusst ich zwar früh schon, aber krasses teil :jeah:
  • Niedlich. Bin gespannt auf das Dings wenns fertig ist.
    [SIZE=1]Hey Jungs, das tut mir echt leid, aber wir brauchen
    [SIZE=2]MEHR POWER [/SIZE] [/SIZE]
    Original von Babeth Seine stolzen Wörter: 18.4 gr, 6 Mm Naben und 15 Mm Schläge.
    Mega meter?????? cool :)
  • what´s the body material? are you sure that your scale is precise enough ? (18,4 grams- i would appraise ~25) :engel:
    helmut
    Original von Der Ingenieur
    Toll Franky. Wir schon seit CW II.
    Ich meinte ja. dass er fertig is
  • @ Mechaniac, The body material is brass.
    And the scale I used is a very accurate scale, used to messure the controleweights of the Senseopads.
    Allowed deviation on the scale 0.01 gram.The 18.4 grams is accurate, and I guess I can even lower that.
    Unfortunatly, full pressure CO2 isn't allowed in ants, 7 bar is the max, so this ram isn't more than a "testcase"
    And the next difficult thing is the valve.(will see if I can build one)
    And I'm currently not interested in building ants. I keep it with heavies,and branching out to feathers.
    But if someone is nuts enough to order a ram like that, I will make it completely from ali, gaining 4 to 5 grams, If that person is willing to pay for the time I put in it...
  • ok, sorry, nice piece of brass... :)
    looks interesting, i have tested a off the shelf iso cylinder 8-25 with ali/ SAS body wallthicknes 0.6 mm, stopped the pressure test at 120 bar, approx. same size than yours, but 28 grams.
    Now i make tests with a small co2 generator, using sodiumbicarbonate, citric acid and a drop of water. Valve: rubber diaphragm with a piezo actuator from a VCR machine, doesn´t work properly at the moment, but i will try again. crazy enough..........
  • Mechaniac.. I'm even can go futher. I aquired a Titanium rod diameter 12mm , with some good machining....
    The chemical CO2 generator... sounds nice, but I was thinking in the line of the very small sodastream bomblets, like in car based powder estinguishers. 22 grams full, with 8 grams of CO2 in it, so tank alone is 14 grams.
  • discovered today in my grabbox:
    3/2 way valve, 8l/min
    unfortunately 24 VDC, but also available in 12
